Software: AvidXPress Pro 4.6 for Mac OSX.
To make this an easy example, When editing in Adobe Premiere, lets say you have a minute clip and its arranged 12345. And now you want to edit this clip in a different order, we will say 34125 or whatever.
When the single AVI is deleted, your edit is offline. Duh. But, you have backed up this clip on a CD-R and copied it BACK to its original location, Premiere acts like this clip was never deleted (your edit is back to 34125).
NOW, in AVID, its MEDIA OFFLINE. I have my MOV clip on my Desktop and I want to relink my clip in my sequence to the file on my desktop...
How can I do this without re-editing my MOV?
There are some excellent downloadable Flash tutorials available for AVID, they are at:
http://www.avid.com/freedv/tutorials/index.asp
If I understand your question... if you have a MOV, then you have exported the clip? Then it's already been coded/compressed, etc & won't necessarily match the settings of your other clips. But, have you tried just drag&dropping the original clip? Works for me! -
Here is the best way for me to explain this...
I put together a local show on our cable network. I rendered the INTRO (about 30 seconds) and its placed at the beginning of the show, BUT I've intercut it through the edits (eg. for commercial breaks, I only use half of it).
Some how the clip was deleted (I still HAVE the master clip in my bin, just MEDIA OFFLINE).
I have the intro saved in After Effects, which I would have to render out, but I want to import the intro back into AVID and relink the OFFLINE clip to match my re-render ... just so I don't have to spend several hours finding my in and out points.
Does that help a little? If this were premiere, I would have rendered my file from After Effects and just copied it to the hard disk where premiere thought the file was, and its like nothing ever happened. -
You could ask here too:
http://www.avidaustralia.com.au/index.php?sectionID=1&catID=1
they aren't on holiday!:]
also, you might try Media Sift, if the full intro clip is still on your HD, it might find it:
http://www.senkou.com/ -
Well the problem is that in AVID the MOV file is titled ABCDEFG12345.OMF and when I import the Same MOV file the OMF file is now different. It's a matter of telling AVID that the OFFLINE MEDIA in the sequence is a different OMF file.
I think the way I read was to select both clips and give them the same TAPE NAME and then highlight both files and click RELINK... but on my Mac, if I set the tape name for my recently imported MOV file, I get desktop. So I'm running out of ideas.
Does that make sense? It's hard to explain that haha. -
I'm sure it'll turn out like tieing your shoe: hard to explain, easy to do. You may have to go to the 'horses mouth'... post a Q here at Avid:
http://www.avid.com/exchange/forums/default.asp
linking together 3 videofiles
By marlo in forum Newbie / General discussionsReplies: 7Last Post: 20th Sep 2012, 08:50 -
linking mp4s together(program)
By Dr.Gee in forum Newbie / General discussionsReplies: 4Last Post: 3rd Sep 2010, 04:14 -
Linking Test
By olyteddy in forum TestReplies: 1Last Post: 13th Jun 2010, 17:33 -
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 17:03 -
Linking website to DVD
By bsanti in forum Authoring (DVD)Replies: 3Last Post: 25th Jan 2008, 07:28
