Hi
I received from a client a DVD with 1 hour film on it. I have to re-edit that movie to 5 minutes. What is the best way to import that movie. Can I do it straight in premiere or do I have to convert it to some AVI file.
How can I best convert it to an AVI with as less as possible quality loose.
Thanks in advance
If you are going to make a new DVD then just use Tmpgenc DVD Author, import dvd - video, use the builtin editor and then burn a new dvd.
If you want to do advanced editing in Premiere seaaaaarch,
https://forum.videohelp.com/viewtopic.php?t=302410&highlight= https://forum.videohelp.com/viewtopic.php?t=294536&highlight=
https://forum.videohelp.com/viewtopic.php?t=293033&highlight=
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 4th Jan 2011, 00:35 -
Why does the video I edit in Cyberlink look darker after I edit it and post
By Chubby Johnson in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 06:08 -
Virtualdub - Edit without re-encoding (except at edit point)
By itsonlyme in forum EditingReplies: 2Last Post: 26th Feb 2010, 06:59 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 11:05 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 14:13
