Hay Guys
I just came home from a visit to my parents, they own a CRT sony.
KVDA32M36
They also have a SD set top here and I noticed that the picture seems to be... well like a interlace field order issue but only on the edges of images..
It looks like moving lines
also like pixelation maybe problem with colour gradients
in laymen terms, its nearly like ghosting in analog but with lines and pixelation through the ghost
any insight?
I might try to reproduce the effect in photoshop and post an image..
Results 1 to 10 of 10
This is basically what it looks like, if you could imagin the edges of the image scrolling/quivering ?
That's normal. I forgot what its called but its normal to see that especially with text.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Normal? well does anyone know what causes it or what this effect is called. I'd like to find out more about it. To be honest I really suprised at that because it looks terrible.. any fine detail on images looks like this, I first notice it when they were watching a gardening show and it had a close up of some flowers. all the detail in the flower was taken over by this pixelation interlace line scrolling noise.. and i thought, that cannot be right?
I know of a similar effect if you try to use natural colours in premiere, for example you create a title in photoshop and use it in footage you burn straight to dvd without changing the colour range to suit tv's. But this on everything, text, images, ads, etc
Please help me find out whats happening.. -
What do you mean "almost"? Is this a direct screen cap?
There's an option in the menu of most sony TVs called "VM" or "Edge Enhancement" or "Vertical Movement/Modulation".
Try fooling around with that setting.
8) -
or reducing the sharpness
Is it on all channels? Cable? Satellite? Antenna?
HTPC Digital Signal Reception
By lacywest in forum Media Center PC / MediaCentersReplies: 5Last Post: 12th Dec 2011, 09:42 -
x264 problem: Movie bad + fix = Digital ghosting and out of sync picture
By Kim Jespersen in forum DVD RippingReplies: 7Last Post: 6th Nov 2009, 18:35 -
House-wide digital signal conversion?
By hiramelu in forum DVB / IPTVReplies: 1Last Post: 21st Apr 2008, 06:51 -
Sony Wega Digital signal
By iceironman in forum DVB / IPTVReplies: 2Last Post: 25th Feb 2008, 11:38 -
Local digital signal conversion?
By hiramelu in forum DVB / IPTVReplies: 2Last Post: 9th Jan 2008, 05:20
