Is There any way of fixing bad frames within an avi file
Several files I have seems to have bad frames this causes
the avi to stop outputting but the sound continues on until
I move to the next frame. Please HELP !
When using virtualdub I get 'error fetching frame ?????: videosourceavi error: unspecified error (-100)
Is there anyway of makeing the movie move to the next frame without any intervention from me
<font size=-1>[ This Message was edited by: blunt_rogue on 2002-01-11 01:14:07 ]</font>
You can cut out the bad frame with Virtual Dub. Make a note of where it is and then select the video footage before, save it, select section after, save it, and then join the good sections back together. You will end up missing a second or so of the movie (use key frames) but it will play all the way through.
Originally Posted by blunt_rogue
Or you can try to just set video and audio to dirct stream in Virtual Dub and save it like a new AVI file.
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 18:39 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 09:15 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 16:00 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 13:27 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 04:39
