  1. I'm fairly inexperienced with video, although I have used VirtualDub for some time for basic conversion applications.
    I had read that VirtualDubMod does all that VirtualDub, plus more. So I decided to use it instead from now on (especially as I will be working with MPEG.)
    But, using version 1.5.10.2, when I opened an AVI file I got this:
    "AVI: Type-1 DV file detected -- VirtualDub cannot extract audio from this type of interleaved stream."
    The file opens fine in VirtualDub, and plays audio and video. Can anyone help please?
    BTW, I did try to use the forum via the link at http://virtualdubmod.sourceforge.net but it was
    inaccessible.
    I can provide file information if required.
    Terry, West Sussex, UK
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Try converting it to type 2 with the ULead utility. Or stick to VirtualDub for DV type 1 - Besides reading mpg, there's not much that's better in VDubMod compared to regular VDub.
    You can have both installed simultaneously.
    /Mats
  3. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Or use VirtualDub-Mpeg2. It has kept up with the updates of the base VirtualDub and can open Type1 as well as Mpgs.
    Buy My Books
  4. Thanks both. Duly added VirtualDub-Mpeg2 to my tool collection.
