Have a problem with a converting a divx, Virtualdub says that the framrate is 25.056. When I frameserve to TMPGenc the sound goes out of sync (even tried to convert it to wav first) although the divx itself plays perfect. Now I think the only solution is to convert the divx itself first into 25 fps and then add the sound but how can I change the fps of a divx without it getting choppy?
Why are you frame serving? Are you adding resize filter, changing frame rate... can you open the divx with TMPGEnc and do a sample? What frame rate are you selecting in TMPGEnc? Maybe a little more info.
Good Luck
just encode in tmpg at fps of 29.97 if your encoding res is 352x240, 480x480 or 704x480
Use 25 fps in tmpg if res is 352x288, 480x576 or 720x576
ShiZZZoN PzN
Everyday is another payday and I am one step closer to becoming the one. -
Well I got out of this mess myself but thx for the help. What I did was strip the sound using virtualdub, then I used the settings direct stream for the video and no audio, let virtualdub output the divx to 25 fps, used that created avi with the sound I stripped and served it with my subs to TMPGenc with a beautifull VCD as result with everything in sync.
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 05:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
Divx to NTSC DVD: is Dgpulldown needed if Fps is 23.976?
By kalii2 in forum Video ConversionReplies: 4Last Post: 20th Jan 2008, 08:29 -
Blocking 971.871.056 million IPs and HTTP
By fLYtRap in forum ComputerReplies: 22Last Post: 24th Jul 2007, 13:03
