I've been fooling around with it, converting from mpeg to xvid, but the resulting avi files are not recognized by some other programs (Virtual Dub, Windows Media Player, Media Player Classic.) Something odd in the header; these programs do not recognize the Xvid codec in the Avi file. (And yes they recognize it with Xvids encoded with Virtual Dub on my machine.) Anyone else having this problem?
Results 1 to 12 of 12
If I want quality, I use VirtualDub Mod or one of the VirtualDub variants because of the control and the options.
I reserve SUPER for the less common formats when quality is not the major concern. I haven't tried it for MPEG to Xvid. I don't know why it would output a non-standard Xvid, though. You might drop one of the non-standard ones into Gspot 2.52 and see what is different about it.
G-Spot can find some of the information in the header (like xvid) but it doesn't find all of the information like those boxes which indicate BVOP NVOP.
The files are not larger than 1GB.
I would agree that Virtual Dub is a better bet for Xvids, but I wanted to try it out with SUPER. The files do play on my Oppo stand-alone player and look good, but I'm concerned that they are not compatible with other programs. -
This is the error message I get in Media Player classic when trying to play a SUPER's Xvid avi.
The following pins failed to find a connectable filter
AVI splitter
Stream 0
AVI Splitter
Media Type 0:
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
subtype: FOURCC GUID {64697678-0000-0010-8000-00AA00389B71}
formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A}
bFixedSizeSamples: 1
bTemporalCompression: 1
lSampleSize: 921600
cbFormat: 88
VIDEOINFOHEADER:
rcSource: (0,0)-(0,0)
rcTarget: (0,0)-(0,0)
dwBitRate: 0
dwBitErrorRate: 0
AvgTimePerFrame: 333667
BITMAPINFOHEADER:
biSize: 40
biWidth: 640
biHeight: 480
biPlanes: 1
biBitCount: 24
biCompression: xvid
biSizeImage: 921600
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0 -
That sounds more like a codec problem than a player problem. Especially if VD doesn't accept the file. I just tried converting a MPEG to Xvid with SUPER and VirtualDub had no problem opening it. I used the default settings in SUPER. Maybe something there was set different, though I don't see any settings there that should bother VD.
Or maybe there is a problem with your Xvid codec when playing back the file. In that case VD probably wouldn't accept any Xvids, though.
G-Spot 2.52 Beta
Xvid 20:18:22 December 30 2005
Yes it is weird because VD recognizes other Xvid avi, but it doesn't recognize the ones from SUPER.
This leads me to believe that the way SUPER is writing its header is confusing to some programs.
AVI-Mux Gui file info feature's analysis of the SUPER avi describes some of the header information as written by a broken program.
I was resizing in my encodes with SUPER (480x480 to 640x480 but it did not actually resize), so perhaps that was the added complication. -
If you want the whole story, I did try the various options.
It just crashed with the direct show option enabled, so I disabled that.
Using mencoder made Xvids that froze after the first few frames.
Using ffmpeg gave me Xvids that did play on my Oppo stand alone DVD player, but had the header problems that started this thread.
My sense is that right now SUPER is good for simple format to format conversion, but buggy if you want to do other things as well (like resize, especially from a non-standard resolution). -
On your Oppo, or on the computer?Originally Posted by David K
Well... someone more familiar than I with the inner workings of ffmpeg and mencoder would have to reply, here, though I thought they didn't have problems with resizing, from most resolutions. I don't know if recent builds (or the custom builds used in SUPER) encode for a specific version of XVid, either.Originally Posted by David K
I'm not sure, but you might also try utilities like AVI Recode. I don't know if that'll fix the header problems, though.If cameras add ten pounds, why would people want to eat them? -
Most builds are statically linked, so they use whatever lib they were linked against. Can also be linked dynamically though in which case the version is determined by whatever build of xvidcore.dll you have.
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 22:05 -
2 xvids codecs in vdub
By catdaddio6 in forum Video ConversionReplies: 1Last Post: 26th Aug 2008, 16:29 -
Is this how to make Hi-Def xvids?
By Topher5000 in forum Video ConversionReplies: 4Last Post: 17th Sep 2007, 16:05 -
Can't get Xvids to work in VDub
By clos in forum Video ConversionReplies: 3Last Post: 9th Jul 2007, 12:47 -
Close Captions Instead Of Subtitles In XViDs
By 888888 in forum DVD RippingReplies: 3Last Post: 3rd Jul 2007, 16:03
