I have an ATI TV Wonder Elite PCI card and the quality of the video is very good. Unfortunately it has a couple of hiccups:
1. The software that comes along with it is really terrible. It takes so long to start watching cable channels and switching to different channels.
2. There is a 2 second lag in the visuals and audio for the composite input being shown. I want to record game play videos from my ps2 but the lag makes it unbearable to play on it.
3. Support for ati products is terrible as well. I had to look at other forums to find answers.
I had to use 3rd party software just to make it work seemlessly.
Chris TV is a great piece of software. Unfortunately you have to buy it in order to keep using it. DScaler used to work with my old ATI Wonder Pro but it wouldn't work for my ATI Wonder Elite. I asked the DScaler forum but no one has answered my question. Winamp TV (plug-in for Winamp) works really well for composite video. Its almost perfect if there wasn't a slight audio lag and motion blurring.
How good is the audio and visuals provided by the Hauppauge WinTV PVR 150 MCE Bundle? Is it better than an ATI Wonder Elite? Is there a lag when you use the composite input with a game console? Are there any solutions to it like using 3rd party software support?
According to the store I will buy it from it has a TV out. Is this true?
http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10068...03&catid=10524
Thanks for the help.
Results 1 to 1 of 1
[Sloved] Hauppauge WinTV PVR-150 capturing using off air cable plug
By Wizard23 in forum Capturing and VCRReplies: 4Last Post: 11th Feb 2011, 22:07 -
capture VHS with Hauppauge PVR 150?
By shun in forum Capturing and VCRReplies: 13Last Post: 24th Jul 2010, 19:11 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 11:39 -
Hauppauge PVR 150 compatibility with my OS
By GangstaRap in forum Capturing and VCRReplies: 11Last Post: 14th Mar 2008, 11:03 -
Hauppauge WinTV PVR-150 ($60) vs. ATI TV Tuner 650 ($100)
By RoganSarine in forum Capturing and VCRReplies: 2Last Post: 13th Dec 2007, 03:48
