Hi, what programs can you suggest I use for cropping a DVD movie with a ratio of 2.35:1 down to approximately 2:1 with? I am hoping the the resulting video will still be in DVD quality.
The easier way to watch a 2.35:1 Movie onTV is to use the zoom feature on your DVD player. The better DVD player like JVC, and Samsung have zoom 1.5x, that show 2.35:1 Movie with just couple of thin black bars.
There's nothing odd about it. Francis Ford Coppola cropped Apocalypse Now Redux to 2:1 for its DVD release. It's a good compromise between viewing a movie so wide on a screen so small (i.e. many times smaller than a movie theater screen). I would like to do the same with a DVD I own.
So, there aren't any programs that can do this? -
Not automatically. The basic process would involve
1. Demuxing the video from the DVD
2. Cropping and then resizing the video. This will be a straight centre crop, and not a re-framing of the image within the new frame. The image then needs to be resized to spec resolution
3. Re-encode the video
4. Re-muxing the video back into the DVD
Step 1 can be done with rejig or similar
Step 2 is best done with avisynth, and then frameserved to step 3
Step 3 whatever encoder you have
Step 4 is the more difficult part - look at guides for IFOEdit, or PGCEdit to find out how to prep and remux material. Not for the feint of heartRead my blog here.
cropping dvd movie
By comicfanman in forum DVD RippingReplies: 2Last Post: 2nd Sep 2010, 23:13 -
My Widescreen TV Is Cropping Out The sides Of My DVD'S.
By big_boi97 in forum Newbie / General discussionsReplies: 10Last Post: 8th Sep 2009, 21:27 -
DVD->DIVX using Xvid4PSP: Aspect/cropping issue
By thomas_fogh in forum Video ConversionReplies: 7Last Post: 5th Oct 2008, 16:37 -
4:3 LBX DVD to Divx cropping question
By ecc in forum Video ConversionReplies: 3Last Post: 1st Oct 2008, 13:11 -
**HELP** Cropping a DVD Video.
By kal1982 in forum Authoring (DVD)Replies: 5Last Post: 30th Jun 2007, 21:26
