i have 2 OGM video files that i would like to burn to DVD, presently i use ConvertXtoDVD and i cant use that. I could convert them to AVI or Mpeg but i need a program that will do so. ALso i want to prevent sync lose! lastly i need a video player that plays OGM files. i dont have one. if anyone knows hit me up please!
Results 1 to 13 of 13
CAN I HAVE YOUR COOKIES? -
PLay with VLC or install Haali Media splitter and ffdshow and use wmp,mpc.
OGM to Converters -
ConvertXtoDVD should be able to convert ogm's. What exactly is the problem?
I use VLC to play and VirtualDub Mod if I want to convert them. Most of the video is Xvid format with Ogg audio. VDM should be able to handle that. But they may be some other format in the OGM container. OGM can have several audio channels, along with subtitles, so some programs may have problems with that.
Doesn't mean that it can't open them. At least if it is still using libavcodec/format, then it supports ogm since libavformat can parse ogm files. Didn't used to be able to though so it is possible that the libs they are using are too old. If they would release the changes they made, then I could provide more recent updates.
It means that if they released their source changes as legally required by the GPL license that libavcodec/format are covered under (if you have GPL libs enabled, which I believe they have), then I could release updated dll's. Currectly I could only do stock dll's which I have tried and they don't work.
ffmpeg gets updated usually a couple of times per day and unless their is a major API change then new dll's should work without the need to update convertx. -
You wait for VSO to release new ones. As I said unmodified ones don't work.
Hi,
Just to let you know
ConvertXtoDVD version 2.1.0 just came out claims to support the ogm format now. -
As I said all it would require is updating libavformat. Should also support VP 5/6 since libavcodec now does. Could be they missed that update. Pitty since it would have meant support for VP6 flv's.
Converting OGM files to AVI/MPEG with subtitles
By StevoK in forum Video ConversionReplies: 1Last Post: 4th Feb 2010, 01:50 -
VLC & WMPC are no longer playing avi files.
By marzipan in forum Software PlayingReplies: 6Last Post: 19th Jun 2009, 10:57 -
converting RM & TS Files
By Astonlee in forum Newbie / General discussionsReplies: 0Last Post: 11th Dec 2008, 08:02 -
converting, burning, and playing avi files
By unionman4077 in forum Video ConversionReplies: 1Last Post: 27th Feb 2008, 17:01 -
Samsung HT-TX75 not playing my Divx & Xvid files
By danimaltron in forum DVD & Blu-ray PlayersReplies: 7Last Post: 19th Nov 2007, 20:02
