OK, I got the new burner (Sony DRU-810A) bundled with Nero Express. I can burn DVD from my files that are in mpg. format but not the ones that are in Avi. I know they have to be converted and I have tried that using Avi2DVD and FreeEnc. Nada. IT still won't work. Is ther just one converter program thats works best with Nero? And is it cheap? FREE???
Thanks 8)
Results 1 to 9 of 9
OH! I have to go mow the yard. I will be back in an hour or so.
If I don't respond to fast its cuz I'm proably borderline senile and am probably driving in circles within circles -
Which of the 48 guides on AVI to DVD found under CONVERT left have you read and tried so far?
/Mats -
Originally Posted by mats.hogberg
Who stuttered? Well now, Maybe I did not go down far enough in the tree root there to find the solution. I'll check them ALL out
"I may be Bach" said Arnie. -
Sounds like they really gave you a stripped down version of Nero. Nero usually can convert AVI to DVD, but the quality's not real good.
Have you tried dragging and dropping an AVI into Nero and told it to burn as DVD? Maybe you have. I try to avoid Nero Express. You could also see if you can use Nero without using the Express version as that might work.
DVD2SVCD is free and it can convert AVI to DVD format. You might try that, but it's not the easiest program for newbies to use because it has a lot of settings you may not understand. -
Its that easy to tell a nebie huh?
I have been messing with avi2dvd now for 2 hours. It almost works. Then it wants an audio format and there is nothing to choose from in the dropdown.
Now I've got AVI2DVD, Nero, Infrview, and FreeEnc on the desktop and still can't get the darn thing to convert.
Well, I guess I'll DL the one you mentioned and try that.
I think from now on I will download videos in the right format first so I don't have to contvert them
Now thats a nebie tawk'in -
Best is to get a DVD player that plays DivX/XviD AVI too - they are really cheap these days - you can probably get one for mowing the yard for a few hours
At least much less time you're likely to spend trying to convert stuff!
/Mats -
Convertxtodvd (or its free predecessor - divxtodvd) might be worth a try here.
If in doubt, Google it.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
