Hey guys,
I hope you can help me with this.
I have downloaded a few video files from Limewire and am having trouble transferring them from onto dvd to play on my dvd player. I have tried a whole bunch of software(divx converter, cucusoft, dvd santa), but none of them seem to work.
Any ideas???
Lisawatsuk
Closed Thread
As thecrock said, what is the format of the videos?Originally Posted by lisawatsuk
If you want to play these videos on a DVD player you need to get them a format that your dvd player will recognize. Typically a DVD-Video type format that consists of your standard VOB files.
Note: some DVD players will play regular mpeg files that are burned on a finalized, data DVD or CD disc.
For example, I have some video files that are in the AVI format. These files need to be converted to a DVD Video format. I converted them to MPEG-2 format then used a DVD authoring program to generate the necessary VOB files. After that I used a DVD burning program to burn a DVD and now those videos will play on my DVD player.
Hope that helps.
Transferring files between 2 PC's using ieee
By dbanimal in forum ComputerReplies: 22Last Post: 30th Dec 2009, 03:27 -
Trouble Transferring Files From DVD-R to Computer
By meadowburke in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 12th May 2009, 15:14 -
transferring files from the PC to mobile phone
By sumeshkri in forum AudioReplies: 3Last Post: 19th Sep 2008, 08:26 -
Transferring Music Files
By mccoady in forum ComputerReplies: 5Last Post: 14th May 2008, 12:41 -
Transferring files to ffmpegX
By Bigdaddy04 in forum ffmpegX general discussionReplies: 2Last Post: 7th Mar 2008, 14:42
