Hello
I read the region free hack for the BOSE 3-2-1 System II in the "DVD Player region free list" "https://www.videohelp.com/dvdhacks.php?select=Bose+3-2-1+GS+Series+II". I tried on my just buyed system which i got from the US.
I want to make it regionfree to accept European DVDs.
The hack is not working on my system. Perhaps i have misunderstood the keys?
i assigned a picture to this mail where i indicated the Keys to press for the region free hack.
Are they in the correct order?
Perhaps the original posters may read my mail.
Thanks in advance
Einar
Results 1 to 9 of 9
It is common for hacks that work on older models to not work on new models of the same player. Your best bet if you want a region free player, is to buy a region free player.
Google is your Friend -
theres another variation on that hack on that page too..
have you tried that??
if that doesnt work either,then more than likely they have discovered it,updated the firmware on newer models and locked you out.
those hacks are around 8 or so months old..LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
Thanks for you answeres.
I tried all. The pressed keys are all the same.
I simply wanted to know if the keys i pressed have been the correct ones.
In the moment i use a second DVDplayer to play DVDs.
Thanks -
You need the remote codes and the firmware updates, go here...
http://www.smartgroups.com/groups/hometheatre -
Bose 321 gxII---------Any hacks that work? For see dvd zone 2 or multi region (now it is Region 1)
Manufacturers sometimes make changes in the models that break hacks. There may not be a working hack for this player now.
Its not broken. You need the updated firmware and procedure.
http://homeavi.pro-forums.com/
Read the FAQs for your unit. it is easy
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 17:12 -
region free hack?
By adriansherman in forum DVD & Blu-ray RecordersReplies: 1Last Post: 25th Apr 2011, 01:19 -
Region Free Code for LG DN898--tried hack on site, it didn't work! :c
By lollypopBADgirl in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Mar 2011, 22:17 -
LG HT965TZ Region Free Hack
By notquitethere04 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Nov 2010, 14:46 -
Bose 321 GSX How to make it region free?
By wouter3 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 1st Nov 2008, 08:23
