I am looking for a good converter which converts video in any format to Divx Avi format. I tried different softwares like AutoGK, Gknot , VirtualDub . All these softwares takes a lot of time for converting the video. I tried convertmovie 4 from www.movavi.com it takes only less time for converting video and the quality is excellant. This is not a freeware. Now that I am looking for a similar kind of freeware which gives a good quality conversion with lesser time. could anyone help me.
Thanks,
Thiyagu
Also unreliable, or questionable quality, and with dubious supportTry WinAvi video converter, its not free but cheap
If you use the official codecs, as AutoGK etc do, then the encode time will be around the same for each, and is mostly CPU dependent (all else being equal). But at least you know what you are getting, and it will be compliant.Read my blog here.
Divx to AVI Converter
By blueskat2002 in forum Newbie / General discussionsReplies: 3Last Post: 26th Feb 2012, 23:32 -
Divx Converter Problems
By Maritimer in forum Video ConversionReplies: 11Last Post: 18th Dec 2009, 14:00 -
Divx Converter
By jrodrigu123 in forum Video ConversionReplies: 2Last Post: 10th Dec 2009, 19:14 -
best avi (divx/xvid) to cd-r (vcd) converter
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 8Last Post: 15th Sep 2008, 13:36 -
avi to DivX using divX converter pro
By Deaf Raiders in forum Video ConversionReplies: 3Last Post: 19th Dec 2007, 13:28
