I asked a similar question already, but I couldn't find the response given.
I want to import some MPEG-2 files.
I have Adobe Premiere 1.5.1, and have VirtualDub.
I try to frame serve the file I want to put into Adobe, but it doesn't let me.
I made sure too that it had an *.avi ending too, but the signpost file just doesn't get accepted.
I'm also confused by what FrameServer Network Client is meant to be used for? It asks for a computer name and port. Computer name I think I know, but the port I don't know.
If you aren't serving across a network, the port number is pretty irrelevent. If it has a default, use it. Generally, frameserving is used to pass through to an encoder, not an editor. It can be done with some editors using the vfapi interface. I know Vegas will read vdub signpost files using this, so Premiere should as well. I don't know how slow it will be, or how it might restrict your editing. If you are doing multiple editing sessions, you have to remember to start serving again when you come back.
Read my blog here.
Read my blog here.
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 19:57 -
Reversing PAL speedup and frameserving
By Ennio in forum Video ConversionReplies: 23Last Post: 28th Jan 2010, 15:28 -
FrameServing from Vegas 9 to MeGUI
By Kit-10 in forum Newbie / General discussionsReplies: 8Last Post: 4th Dec 2009, 17:12 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 21:31
