After installing the new Windows Media PLayer 11 on my computer, I was unable to play almost all video files. I downloaded a few codecs, which fixed most of my problems, except for that fact that I cannot play wmv files or uncompressed AVIs, with any program. Any ideas on the fix? Thanks in advance.
For avi files, you will need the appropriate divx codec installed. The wmv codecs should be supplied by WMP, it should download them on its own. It is also possible that you have corrupt files, in which case codecs won't correct the problem.
Try a standalone player such as MPC.Google is your Friend -
Originally Posted by drewzor
C:\My Documents\001.wmv::Raw Video 1
Media Type 0:
Video: Windows Media Video 8 320x240 29.97fps 395Kbps
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
subtype: Unknown GUID Name {32564D57-0000-0010-8000-00AA00389B71}
formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A}
bFixedSizeSamples: 0
bTemporalCompression: 1
lSampleSize: 0
cbFormat: 92
VIDEOINFOHEADER:
rcSource: (0,0)-(320,240)
rcTarget: (0,0)-(320,240)
dwBitRate: 395000
dwBitErrorRate: 0
AvgTimePerFrame: 333667
BITMAPINFOHEADER:
biSize: 44
biWidth: 320
biHeight: 240
biPlanes: 1
biBitCount: 24
biCompression: WMV2
biSizeImage: 25653
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
pbFormat:
0000: 00 00 00 00 00 00 00 00 40 01 00 00 f0 00 00 00 ........@...ð...
0010: 00 00 00 00 00 00 00 00 40 01 00 00 f0 00 00 00 ........@...ð...
0020: f8 06 06 00 00 00 00 00 63 17 05 00 00 00 00 00 ø.......c.......
0030: 2c 00 00 00 40 01 00 00 f0 00 00 00 01 00 18 00 ,...@...ð.......
0040: 57 4d 56 32 35 64 00 00 00 00 00 00 00 00 00 00 WMV25d..........
0050: 00 00 00 00 00 00 00 00|e9 8b fc 80 ........é‹ü€ -
A little ironic that MS latest attempt at making a media player doesn't play their very own wmv format...
/Mats -
Originally Posted by mats.hogberg
Of course, installing the "new" version of any software isn't always a good idea either (Nero 7 anyone?).
If it will uninstall, then I would remove it and reinstall 9 or 10. Knowing MS, it won't, in which case you will most likely end up reinstalling the OS.Google is your Friend
CUDA don't work, why?
By lovelylisa in forum Video ConversionReplies: 38Last Post: 24th Jun 2011, 16:19 -
BD Sup to srt and why they don't work all that weLL.
By cal_tony in forum SubtitleReplies: 2Last Post: 4th May 2011, 09:17 -
DVDRemake don't work?????????
By bens dad in forum Newbie / General discussionsReplies: 7Last Post: 4th Jan 2008, 12:18 -
Can't get x.264 to work in WMP
By sappiajk in forum Media Center PC / MediaCentersReplies: 4Last Post: 22nd Nov 2007, 08:46 -
Dvd's don't work after a while.
By FreeDiver in forum DVD & Blu-ray WritersReplies: 15Last Post: 11th May 2007, 00:46
