    Apr 2006
    Thailand
    I use DVDLab-Pro
    The scenario is like this :
    I have 3 movie , first and second one is 16:9 and third one is 4:3.
    So I have to create seperate VTS for each Movie.
    VTS1 -> 1st,2nd Movie
    VTS2 -> 3rd Movie
    then I create Root Menu in VTS1
    VTS1 -> 1st,2nd Movie,Menu
    VTS2 -> 3rd Movie
    But Menu in VTS1 cant' link to Movie in VTS2
    Menu is contain
    "Play 2nd Movie"
    "Play 3rd Movie"
    (1st Movie is only Intro. So it doesn't need to select from Menu)
    I try to create VMG Menu, it can link to both movie but It can't act as Root Menu (so when I select Menu button in my DVD Player, It doesn't go to VMG Menu I create)
    Requirement :
    - When DVD is strated, It's play 1st Movie -> 2nd Movie (menu doesn't appear unless put "Menu" button in DVD Player or 2nd Movie is end)
    - Menu can link to 2nd Movie and 3rd Movie
    I really appreciate for any suggestion,
  2. Member GeorgeW's Avatar
    Feb 2005
    In the Connection window, rt-click/Add/Bridge (or use the bridge icon).
    You can link a menu button to the Bridge, then connect the end-link of the Bridge object to the movie in the other VTS.
    Regards,
    George
