I am looking to archive a 100-200 hours of family memoribilia. I am planning to archive the video onto a Lacie as well as backing it all up on DVD's. I am using Final Cut Pro 3. Optimally, I would like to capture the video at a compression setting that will allow me to get a 2 hour VHS onto a single DVD without compromising the video too much - which I reallize is relative to the individual. A DVR recorder seems to convert TV video without compromising the quality at all. But a VOB file won't play on a computer. Is is possible to get the same results with Final Cut.
VOB files will play on a computer, even a Mac
What you need to find is some Mac software that will allow you to demux the video and audio streams from the DVD so you can edit them further in Final Cut Pro. You can start your search here -> https://www.videohelp.com/tools?s=15#15 AviDemux might be a start.
That said, unless the edits you are making are simple cuts, I would be capturing directly to the PC first, making whatever edits and adjustments are necessary, then outputting in two formats - one for archiving and one for DVD. The reason being, mpeg doesn't like repeated encoding. If you edit mpeg and make more than just I-frame simple cuts, re-encoding must occur, and quality can drop quickly.Read my blog here.
Diamond Video Capture VC500 Problem + Settings
By Firelance in forum Capturing and VCRReplies: 1Last Post: 18th Feb 2012, 05:04 -
Video Capture Settings.
By Green_Tape in forum Capturing and VCRReplies: 1Last Post: 4th Oct 2011, 23:37 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
Capture Video Settings - Input Type Missing
By TechnoBill in forum ComputerReplies: 2Last Post: 2nd Jun 2009, 05:02 -
Capture settings or other issue? (Interlaced video, and a few questions...)
By DonnieC in forum Capturing and VCRReplies: 5Last Post: 30th Sep 2008, 13:03
