I want to batch convert about 50 aac files to mp3. Now GoldWave worked When I was trying it out but now it say the file have an unreconisable compressor (I changed some things since I tried the program out like upgraded nero burning rom and uninstalled some programs that I dont remember what they were) I would like to know what decompress to use with GoldWave 3vix and coreacc do not work and I have checked all 3vix things in GoldWave under directshow.
Since you have nero you could try the encoding tool in nero.
Sadly not all aac works. Only if the aac contains one stream, it doesn't work with multiple streams. -
Foobar wont work it says file produces garbel at 00:00:00 but they play fine Dbpoweramp wont work because I need to batch convert and nero wont open the files. Like I said it worked in GoldWave I just dont know witch decompressor to use. I can work with acc to ac3 if that is easyer.
Same question was asked over at doom 9, they suggested giving this a try:-
http://www.bonkenc.org/ -
Actually, if you need to convert 50 files, all you have to do is highlight those 50 files in Explorer, right-click, and select Convert To (which should have a little speaker icon before it, and should send all the files to dbPowerAmp to convert. Unless you want to use different settings for each conversion...)Originally Posted by neobloodIf cameras add ten pounds, why would people want to eat them?
Use FAAD2 to decode to wav. Use "any" mp3 encoder (CDEx) to encode to mp3.
/Mats
AAC and mp3 into mp4 - my mp4boxgui error
By peaceDOThuxDOTde in forum Video ConversionReplies: 0Last Post: 10th Jan 2012, 08:15 -
Found freeware AAC to mp3 converter
By jimdagys in forum AudioReplies: 14Last Post: 22nd Aug 2010, 18:18 -
AAC to MP3
By anirban in forum AudioReplies: 1Last Post: 5th Dec 2008, 13:09 -
AAC 5.1 to WAV or MP3
By Tres_Sol in forum AudioReplies: 1Last Post: 2nd Sep 2008, 23:05 -
Changing an AAC file to an MP3...?
By darkzero297 in forum AudioReplies: 5Last Post: 4th May 2007, 06:54
