  1. it seems the S&P processes .avi.xxx much faster than macPar.
    but does S&P make use of the associated PAR2 files?
    so whats the fastest way to deal with .avi.xxx files and make use of the PAR2 to check the blocks in the .avi.xxx?
    cheers
    rotuts
    MPro 2.66 3GB RAM 1.5TB HD's
    MigliaMiniHD
    QTPro, MPEG2 add on MPlayerX2
    MPEG Streamclip
    24 + 21" samsung flat panels
    G4dual 2GB
    AlchemyDVR card
  2. I run
    $ par2 r /path/to/whatever.par2
    and then double click on whichever of the first twenty or so avi.xxx parts have the AJoiner icon, though MacHacha would do just as well.
    For RAR files I run
    $ par2 r /path/to/whatever.par2 ; unrar x /path/to/whatever.rar
    It may seem odd to use the command line when there are very nice GUI's in existence for but for speed and ease on the CPU it can't be beat. If you ever run Activity Monitor on a G3 iMac while one of the GUI faces for a command line program is running, you can see how much needless overhead there is.
    For consistency I ought to use cat rather than Ajoiner but there you go Some files need to be renamed and MacPar D is the easiest way to deal with them.
