Hello,
I'm trying to view a DVD using PowerDVD; however, my monitor (HP) is not showing the movie clearly. What I mean is the picture is very dark. I tried adjusting the brightness via the PowerDVD Options, but to no avail. Is there something I need to adjust on the monitor? I adjusted the brightness on the monitor as well.
Control Panel->Display->Settings->Advanced and search for overlay brightness settings.
Attached is what shows up. I searched but didn't see anything in refrence to Overlay brightness settings.Originally Posted by Baldrick
brightness%20settings.doc -
What type of video card you own?
Did you install the latest video card drivers?
P.S.
Never link to Word Documents, create a gif file or jpg instead.No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. .. -
Originally Posted by Abbadon
No, I'm on my work pc. Don't want to alter anything.
Gothcha on the 'link', but why not, viruses or it makes it possible for someone to gain access remotely to your pc? -
Either could happen in theory, but mostly not everyone has software to open .doc files on their computers.
Macro viruses are the main concern, also the ability to pinpoint computers remotely by inserting bug crawling code into the .doc format.
Just take a picture of your Desktop/Properties/Settings tab and save it as a .png file, that way you can upload it for us to see what video card model you have.
If the movie you are trying to watch is just burned into a DVD+R media, maybe the transfer was of very bad quality, till you confirm I am only guessing here.No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. .. -
Locally on a PC it is all about your overlay settings in your graphics chip display properties. There is no standardization, it all depends on how Intel, ATI, NVidea et. al. define their overlay defaults*. If you don't like the default using multiple players, then you create a custom overlay setting.Originally Posted by bluemoss
For a particular player, you often have settings targeted at playing a particular file or you can apply those settings to everything played.
Anybody pretending to a calibrated system for editing or authoring will avoid using overlay for monitoring.
*It also depends on your local monitor brightness and contrast settings (monitor EPROM profile) plus the native contrast and pixel display colorimetry of your display CRT or panel.
PowerDVD 7.3 and new BDRebuilder
By dharper40 in forum Blu-ray RippingReplies: 4Last Post: 7th Sep 2011, 08:23 -
PowerDVD
By BobbyScot in forum Software PlayingReplies: 1Last Post: 28th Aug 2009, 13:38 -
PowerDVD Shortcuts
By ocgw in forum Media Center PC / MediaCentersReplies: 0Last Post: 29th May 2009, 12:22 -
can't see anything on powerdvd
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2009, 12:18 -
PowerDVD 6.5 HD playback
By wulf109 in forum Software PlayingReplies: 1Last Post: 22nd Jan 2009, 08:05
