Using Nero 6.0 ultra and was burning a DVD from an avi file. A message box came up saying video was mostly PAL and encode settings were for NTSC asked whether to change to PAL or continue with NTSC. Usually I have had it encode as NTSC. I tried a test piece in PAL and my DVD (A cheap Walmart special) played it ok.
What is the best thing to do keep as PAL or encode as NTSC? Does it take longer if NERO has to change it to NTSC? Quality issues?
Results 1 to 12 of 12
Originally Posted by gthorley
This is a known bug in Nero 6 and AFAIK still hasn't been resolved,go to Custom and select NTSC.
If you are in NTSC land and the source is NTSC then use NTSC. -
What I'd like to know, is how a video can be mostly PAL? I guess it takes the Ahead gurus to answer that one...
/Mats -
Originally Posted by mats.hogberg
Just a guess as to what reason there could be to throw out that sort of message
Regards,
George -
Yes, that'd be one explanation if not
burning a DVD from an avi file -
Regards,
George -
I am strictly a novice at this and have also tried VSO Divxtodvd and winavi but don't seem to get any better results other than faster results. One problem I find is voices are frequently slightly out of sync with all of these programs. Any suggestions as which of the 3 is best. -
If you have to convert to NTSC from PAL, you will have a certain anount of screen stutter on camera Pans and fast motion. You won't notice it where there is less motion or Pans. This is because one out of six frames is thrown out or added (depending on whether your are converting from PAL to NTSC or NTSC to PAL). This can be bothersome if you have a lot of motion or Pans.
...so, better stick to the source format all the way, and get playback gear (DVD player and/or TV) that supports both standards.
/Mats -
Originally Posted by jman98
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
