What are or better yet how do i find what the command line arguments are that ffmpegx sends to ffmpeg...
I want to try to compile a version of ffmpeg on windows that can do the same encoding i do with ffmpegX...
I would like to know easily what all of the specifics are for some of my favorite ffmpegx options in the command line format...
R
>>Bump<<
There has to be a log somewhere that records commands sent from applications... ??
Or al least a way to create something that will echo commands... ??
Anyone...![]()
I think.....
Enable "Open Terminal Window" from the ffmpegX menu.
Now when you encode the ffmpegX places the command onto the clipboard and then pastes it into a shell.
[speculation]It then places a call to 'date' into the clipboard after the encoding process.[/speculation]Code:/Applications/Utilities/ffmpegX/ffmpegX.app//Contents/Resources/pbpaste | sh
If you have a multiple clipboard app -(i.e. butler) the command(s) is now second in the clipboard stack. You can paste it into a text editor and clean up the various calls.
see this post for another angle on the same process.
https://forum.videohelp.com/viewtopic.php?t=277195
I was able to get it to work for me, but tried only one type of file and encoding. I Hope it works for you.
I would like to see this implemented as a feature.
Let us know how it goes and if you found a better way.
How to Use x264 Command Line
By Anonymous344 in forum Newbie / General discussionsReplies: 37Last Post: 2nd Nov 2013, 09:49 -
FixVTS command line arguments pse??
By RogerTango in forum DVD RippingReplies: 2Last Post: 28th Nov 2009, 14:18 -
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 03:23 -
A-B repeat in command line
By alexandre_fs in forum Software PlayingReplies: 4Last Post: 15th Jan 2009, 16:35 -
command line
By exekutive in forum ffmpegX general discussionReplies: 22Last Post: 2nd Jun 2008, 00:44
