This may sound out there, but...
Is it possible to rig up some way to change the channels on a digital cable box remotely? I ask this for purposes of streaming. Right now I privately stream my analog basic cable (to another PC of mine), since there is no need for a box, and I can just run the cable right into my tuner card. But I would really like the expanse of digital channels.
Anyone ever heard of this before?
Nickolas
Hi!
Try searching for freeware Lirc (Linux) or WinLirc (Windows). I made a simple circuit (1 resistor, 1 diode and 1 IR led) and with Winlirc I can control my TV, my cable box, etc... even through Internet.
http://winlirc.sourceforge.net/
Good luck. -
There are also RF (Radio Frequency) type remote controls available. They use a handheld remote control and a receiver unit with a IR light emitter to operate the box just like the IR remote does. You can do a search for 'remote control extenders' and you should come up with a few models.
Great, this looks exactly like what I am looking for. Is there perhaps, a website which sells a premade one of these devices, or is the only option for me to build my own?Originally Posted by AngusMacGyver
thanks,
NickolasNickolas -
Have you seen this page?
http://www.lirc.org/transmitters.html
I made by myself this simple circuit:
http://www.lirc.org/images/simple_transmitter.gif
You will need 1 female DB9 connector, 1 1n4148 (diode), 1 resistor about 4k7 1 IR led and cable enough to put IR led in front of box's CR receiver.
i think you will spend less than US$1 with those parts. After that, use Winlirc to send codes to box. Remember to find codes file for your box.
I wrote a simple program in Delphi to send codes to Winlirc through internet. You can interface with Winlirc:
http://winlirc.sourceforge.net/developer.html
In VB:
http://winlirc.sourceforge.net/vb.html
You must change the value of the registry key "HKEY_LOCAL_MACHINE\SOFTWARE\LIRC\password" to a known password. My experience tells me if you don't set password you can't use it.
I'm sorry my English is weak. I hope you understood me.
Good luck. I can help you if you feel lost. -
AngusMacGyver, actually your english is quite good. That's a interesting circuit. Thanks for it. I'll bookmark it all and give it a try when I have a little spare time. Sometimes the simple solution is the best.
Is there a wireless device to control a cable box remotely and send picture
By MrBiggZ in forum Newbie / General discussionsReplies: 4Last Post: 5th Jan 2012, 20:18 -
Capture and Record US Cable Channels in full HD?
By onesikgypo in forum DVB / IPTVReplies: 14Last Post: 2nd Jun 2010, 23:42 -
How am I getting these cable channels free?
By vid83 in forum Off topicReplies: 11Last Post: 20th Mar 2009, 18:43 -
Some Cable channels suddenly won't come in
By chimneysweep in forum DVB / IPTVReplies: 21Last Post: 6th Feb 2008, 14:26 -
Receiving cable channels
By kanamaster in forum Off topicReplies: 2Last Post: 6th Aug 2007, 22:28
