hi, i'm using the latest version of ffmpegx,
and i'm confused about the de-interlace option.
if i don't check the de-interlace option, then my DVD is unwatchable on a TV.
if i DO check the de-interlace option, then the DVD looks fine on a TV (and computer).
isn't that the opposite of what's supposed happen?
my source is DV (interlaced, bottom field first)
i edit in FCP (settings are for NTSC DV - bottom field interlaced)
then output to qt file.
that goes to ffmpegx, and i use the DVDffmpeg preset.
if i use the preset, and leave the de-interlace option unchecked, then my DVD should be interlaced and watchable on a standard (non-progressive scan) dvd player and TV, right?
but it's unwatchable.
and if i check the de-interlace option, then the output would be Progressive, right?
but that's the DVD that can be watched without jitters on a standard TV.
what gives?
btw, i'm on an intel mac, if that makes any difference.
thanks.
anybody?
i'm sure somebody else out there is using ffmpegx to author DVDs from DV cam footage?
-paul
I don't use ffmpegx and I don't use mac, but it sounds like the field order is being processed wrong when you are encoding interlaced (unchecked). In other words, you are feeding it bottom field first footage, but it is being processed as top field first.
Buy My Books
Originally Posted by soholounge
Hmm, i'm not 100% sure but I guess that "de-interlace" filter applies to the _source_, not to the output movie. I guess interlacing is a process that must be "recalculated" from a de-interlaced source with each encoding step. So you have to enable this option when you're encoding from an interlaced DV source.
Some information there (look the "Problems caused by interlacing" part) :
http://en.wikipedia.org/wiki/Interlace
I don't know how to choose between an interlaced or progressive output with the ffmpeg engine (interlacing mode selection is in the "options" tab when using"mpeg2enc" engine).
Anyone can confirm this ?Jean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés
thanks jps,
if you're right, and i should probably just encode with mpeg2enc, but i can't seem to get good results with that!
ffmpeg has worked better for me, (besides the de-interlace confusion)
i wish someone would confirm your theory, though.
dvd conversion + greek subtitles + ffmpegx
By eleeeni in forum ffmpegX general discussionReplies: 1Last Post: 10th Sep 2011, 11:10 -
ffmpegX & video_ts conversion, or lack thereof
By riegal in forum Video ConversionReplies: 0Last Post: 14th Oct 2009, 05:56 -
eyetv MPG to DVD conversion using ffmpegX
By by-gum in forum ffmpegX general discussionReplies: 7Last Post: 6th May 2008, 19:37 -
Why am I getting crappy DVD encoding? (interlace problems, etc)
By timmus in forum Authoring (DVD)Replies: 15Last Post: 14th Apr 2008, 09:23 -
TMPGEnc & EO Video mpeg-2 conversion problems
By jtalpur in forum Video ConversionReplies: 2Last Post: 28th Aug 2007, 15:46
