Can't find the answer. SEARCH function not working.
I'm using VideoDub and Huffyuv with my ATI Radeon 64 VIVO DDR, Turtle Beach Santa Cruz, 256Mb RAM, and 1600Mhz AMD Tbird. I'm able to capture video, but when I try to play it back I have audio and about 1/4 inch of my video at the top of the playback screen and the rest is all green. Please, advise me what I'm doing wrong. TIA
I had the same problem and the following seemed to fix it. I don't know why, but.....
go to control panel
select multimedia
select devices
check under 'video capture devices'
I removed all but 'Microsoft WDM image capture'
Thanks for the repley db7731, but Microsoft WDM image capture was the only one there.
Still not working.
I had the same problem. I'm using the AGP 64DDR VIVO with Windows XP Prof. I had to uninstall the display drivers and all ATI software, reboot, and reinstall using the Win2k drivers and MMC 7.0. After that Vdub was able to pick it up right. Hope this helps
EasyCap USB 2.0 Video Capture requesting name & registration code Help Req
By Teac23 in forum Capturing and VCRReplies: 4Last Post: 21st Nov 2010, 23:22 -
Req: Configuration help for best audio/video using freeware and PC
By Morcas in forum Newbie / General discussionsReplies: 4Last Post: 7th Jun 2009, 08:47 -
Req. .rv to .wmv converter or .rv player
By naufil in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2009, 05:20 -
[REQ] Tool to create a video with photos / mp3
By qbecerra in forum Newbie / General discussionsReplies: 13Last Post: 27th Jan 2009, 15:28 -
REQ : - SOUND Distorted from footage
By mojoeuk in forum EditingReplies: 2Last Post: 23rd Nov 2007, 15:54
