Just curious to hear some feedback on performance when rendering projects?
4400 is a lil more powerful than the 3800, but that's good to know
Doesn't Intel generally perform better when rendering than AMD? -
All other things being equal, (Which they never are.
) CPU speed is the most important factor for encoding speed. Intel and AMD have gotten fairly close in performance. It may come down to the motherboard chipset, how memory is handled, bus speeds and a lot of other factors to determine which performs better in certain operations. Even dual CPUs may not be faster if the encoder programs don't make use of their capabilities. Same thing with 64bit CPUs compared to 32bit and the operating systems used.
At least in the past, the big difference was price. AMD had more 'bang for the buck', but Intel is competitive again with pricing. But I still like AMD.
EDIT: I have a 3800+ AMD AM2 Athlon in one of my computers, but it's not a X2. -
Is it automatic? Or are there any configuration changes we should make to take full advantage? Does that mean rendering should be 2wice as fast on a Dual CPU machine?
Yes.Originally Posted by snapware
No, two CPUs are not twice as fast as one CPU. There are other bottlenecks, and there are dependencies in software that makes it close to impossible to get twice the speed of once CPU out of two CPUs. Two are plenty faster than one though.Does that mean rendering should be 2wice as fast on a Dual CPU machine?Terje A. Bergesen
Ex-AMD engineer rips AMD management
By deadrats in forum ComputerReplies: 0Last Post: 17th Oct 2011, 19:39 -
Sony Vegas Users? Simple editing question...
By jnaizer in forum EditingReplies: 12Last Post: 25th Oct 2008, 17:07 -
Need input from SONY VEGAS 8 PLATINUM users -- not pro
By jg0001 in forum EditingReplies: 0Last Post: 23rd Nov 2007, 12:10 -
AMD 64 4000+(1x2.4GHz) or AMD 64 X2 3800+ (2x2.0GHz)
By neomaine in forum ComputerReplies: 19Last Post: 13th Jul 2007, 11:24 -
I have a Denon DVD 3800, wich software and dvd-media do you use
By xsienix in forum DVD & Blu-ray PlayersReplies: 10Last Post: 25th May 2007, 16:10
