I have a older HPn511 pc..and it seems now that if it sits idle for very long if you click on a icon to load or start a program nothing happens..should i reload the whole thing or is therre a way to just reload xp?
If the 511n has the standard 128MB of RAM you may want to replace the 2-64MB chips with something a little larger. 128MB of RAM + Windows XP = no fun.
it has 256
is there a way to just reload winxp rather than wipe and reload the whole system -
Nope. You insert your restore disc and reset it to factory specs.
I suspect this old socket370 celeron is about ready to go bye bye.
Reload Vista?
By videobread in forum ComputerReplies: 10Last Post: 23rd Mar 2012, 21:14 -
Having to reload mpeg2enc/mencoder/mplayer each start
By SeveralButchersApron in forum ffmpegX general discussionReplies: 5Last Post: 31st Aug 2008, 10:41
