I am using VirtualVCR and I have noticed that in the audio I can hear what sounds like static in my captures. I am capturing from video that was recorded to my DirecTV DVR so I can redo it. I have tried other software, including the ATI software and IUVCR and there is no static. Also, when I play the original again, there is no static. I have concluded the problem is with VirtualVCR. Has anyone else had this problem ?
Thanks !!
Seize the Day
Okay I have solved the problem, apparently if I do not compress the audio, the static goes away. I was compressing the audio using PCM 48000 768 kbs. Anyway that is what was causing the problem.
Seize the Day
Little setting problems with VirtualVCR
By Greycat in forum Capturing and VCRReplies: 10Last Post: 28th Jul 2015, 18:07 -
VirtualVCR cap fails in virtualdub...
By Asesinato in forum Capturing and VCRReplies: 36Last Post: 12th Apr 2012, 11:43 -
VirtualVCR Tweaker
By Torrential in forum Capturing and VCRReplies: 1Last Post: 21st Apr 2010, 04:24 -
VirtualVCR help
By LittleJimmy in forum Capturing and VCRReplies: 3Last Post: 11th Jan 2009, 23:34 -
VirtualVCR and ATI TV Wonder
By moorthy in forum Capturing and VCRReplies: 1Last Post: 28th Sep 2007, 18:46
