What project settings should I use for the capture? Same as with MiniDV NTSC,i.e.,DV NTSC Standard 48KHz? The generated captured file will be 13Gb/hour as in MiniDV SD capture? Thanks.
BINGO.
The DVD format uses 16-bit 48k audio and as you guessed the file size will be as you say because after all the Canopus converts to DV AVI format.
Please note that the Canopus ADVC-100 has switches for 7.5 IRE BLACK and 0.0 IRE BLACK. You should use the 7.5 IRE BLACK setting for all NTSC except for Japanese NTSC which is 0.0 IRE BLACK. All other videos (such as PAL format) should be 0.0 IRE BLACK.
I can't think of an easy way to explain it other than to say do what I said above for the settings.Originally Posted by alegator
If you do a search on this website for "IRE BLACK" I am sure a lot of threads will come up for you to read and learn more.
- John "FulciLives" Coleman
P.S.
Here is just one good thread worth reading: CLICK HERE"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Capturing video from a European VHS tape through RCA out
By c627627 in forum Capturing and VCRReplies: 71Last Post: 23rd Mar 2010, 15:19 -
Random freeze or stop while exporting to tape in Premiere Pro CS4
By LghtAndDrk in forum EditingReplies: 1Last Post: 8th Jul 2009, 01:51 -
Question about capturing VHS tape to .avi file
By rfdillon in forum Capturing and VCRReplies: 6Last Post: 27th Jul 2008, 01:44 -
vhs ntsc tape
By erlingre in forum LinuxReplies: 2Last Post: 17th Oct 2007, 17:52 -
Recording a NTSC VHS Tape with a PAL DVD Recorder??
By Lanno in forum DVD & Blu-ray RecordersReplies: 10Last Post: 5th Sep 2007, 04:42
