I have an .avi of Gladiator but when I try to encode it into .mpg in TMPGE, it says that there was an error when trying to encode audio. I tried another encoding program and it said that the .avi file uses compressed audio and it cannot encode it.
Does anyone know a workaround this so I can convert this .avi file into an .mpg?
Use VirtualDub to extract the audio from the movie, "File -> Save WAV" or something, then go into TMPG and for the VIDEO stream choose your video file, BUT for audio choose the WAV file you extracted. Then encode as per usual. This should work, hope it helps.
How do I extract sound using VirtualDub??? Any help would be greatly appreciated. =)
hey you could do all that audio extracting and what not and waste alot of time Or you could just get a good program like Ulead DVD movie studio That program encoded an asf/wmv to mpeg vcd format in the same amount of time that the movie was so in about 2 hours I was watching the movie eating juju beads, but you can do all that extracting audio stuff if you want also if you use ulead dvd theres not a spot or button that says encode What you do is goto storyboard and add file then you goto finish choose your poison (encoding preference) and bingo youve encoded the movie This thing also encodes Smr divx asf wmv its the best capture encoder Ive ever used
hey man i got that program Ulead DVD movie studio what version you got are you sure you can encode with that program avi files to mpg cause i cant find the encoder
in the program .......
DXVA not playing??????plz help
By ansonjoy in forum Software PlayingReplies: 7Last Post: 9th Dec 2011, 08:35 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 10:12 -
I need a guide to convert avi to dvd plz (newbie topic) help
By Death009 in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2007, 07:03 -
VirtalDub ERROR - plz help
By UmmAddan in forum DVD RippingReplies: 3Last Post: 30th May 2007, 17:52
