switchable dvd subtitles? then add it when authoring with for example adobe encore dvd.
You mean to say there is no possibility that I can do this job with Premiere Pro??
It depends on your intent..
If it's something that you want hardcoded into the video, then that's easy..
If you're looking for selectable subtitles on a finished DVD, then Baldrick's suggestion is the correct one.
Subtitles on DVD's are separate streams that are resident on the .VOB file. -
too bad, I would rather look for some freeware than paying for any program, just for subtitles.
Actually, I want to use subtitles as captions for Photo DVD or in some video where I can't offer voice narrations.
iPod touch video with switchable subtitles
By txporter in forum SubtitleReplies: 5Last Post: 13th Jan 2011, 16:35 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
Creating a DVD with Menus and switchable subtitles on Mac OS X
By koke_broke in forum MacReplies: 7Last Post: 27th Mar 2009, 13:43 -
Switchable audio streams in DVD Lab Pro
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 9th Mar 2008, 11:54 -
How do I add switchable subtitles when converting to DVD?
By Baldrick in forum SubtitleReplies: 4Last Post: 15th Aug 2007, 02:32
