My understanding is that this movie clip was originally shot in mini-dv format and is of that quality,however I can only get it saved as a Quicktime file.how do I get back to mini-dv?
I need to quickly figure or find out how to get this to an .avi or mini-dv format for futher processing without (or with a minimal of)quality loss.
How do I best convert a Quicktime movie at DV quality to one of the above formats?
Never done it before.This is a immediate 1 time need.
All advice,program reccomendations and suggestions welcome.
Thanks all!
Bruce
Quicktime Pro will convert but upper level editing programs may read it directly.
http://www.kiva.org/about -
Thanks,
But is there anything for free or a trial version of something that will work??
Bruce -
I don't know about free software but you could get a friend with a MAC toOriginally Posted by Canon GL-2 Guy
1. convert it to avi or
2. record it to a camcorder tape so you can later transfer to your PC or
3. play file on the Mac over IEEE-1394 and capsfer on the PC.
#2 and #3 would need to be done at 1x speed. -
First of all, why can you get ONLY as QT movie? Just because it is transferred using iMovie?
If this is the case then right click on the project and click on 'Show package contents'. There will be a folder called as Media, you will find all *.dv files in there. There is NO need to export them as QT files to get them
(If I understood your question correctly)
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00 -
Problem with QuickTime - DV Format
By parisisal in forum Software PlayingReplies: 3Last Post: 10th Mar 2009, 10:56 -
Problem with Windows Movie Maker not recognising .avi format
By NP11073 in forum Newbie / General discussionsReplies: 4Last Post: 14th Sep 2008, 07:39 -
quicktime movie quality problem
By photofun in forum MacReplies: 10Last Post: 17th Dec 2007, 04:14 -
What is mini DVD format?
By coody in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 18:23
