have bunch of home videos that I converted to DiVX because of it's small size and good quality. I am desperately trying to burn these videos to a DVD. I tried a program that someone told me to use call Cucusoft. It is a DiVX to DVD converter and burner. It does not work well. The video is sluggish and the audio choppy. Can someone help me out with the best way to acheive this? Thanks in advance for your help.
ConvertXtoDVD is the easiest solution, however if you really want quality you will go back to the source. Divx/Xvid may look ok, but they usually are full of artifacts that really show up when converted to DVD.
Read my blog here.
If the videos were converted properly to Divx, then I would second ConvertXToDVD. You can't really get back what is lost, but it does a decent job.
And kman22, as guns1inger mentioned, if you want to move a post, contact or PM a Mod. I'll delete the other post.
Thanks, Moderator redwudz
I Need help simply converting files and burning to DVD. anyone available 1
By Majikwiz in forum Newbie / General discussionsReplies: 2Last Post: 24th Jan 2011, 19:15 -
Burning DVD's after converting to .vob files
By Joyful Noise in forum Newbie / General discussionsReplies: 1Last Post: 7th Mar 2010, 00:37 -
total newbie dvd converting burning
By mujin in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2009, 12:28 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 06:48 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 10:06
