I have TMPGEnc 2.0 and have copied and edited a DVD of TV clips which is less than 4.7mb.
How long should it take to build the DVD? When I first clicked Output it came up as 31 hours! I think that this must be wrong.This is the first one I have done on edition 2.0. I had a trial edition previously.
Originally Posted by Corkhead
Do all your files comply to spec? If not they must be recalculated.
Expect file size to expand to where you need to start over. Fix it now. -
The speed of TMPGEnc depends on your CPU speed, length of your source and your program settings such as output resolution, encoding method (CBR, VBR), motion search precision and filters. Noise filtering increases encoding time dramatically.
"Art is making something out of nothing and selling it." - Frank Zappa -
Panic Over! I have built the DVD and it took just over 2 hours and about 10 minutes to burn.
Why it says such a long time when it first starts I cannot imagine.
Build DVD Structure without Menus and Create them Separately
By Bruno AUgusto in forum Authoring (DVD)Replies: 4Last Post: 9th Nov 2011, 12:50 -
Encore CS4 DVD Image Build is incredibly slow
By aple in forum Authoring (DVD)Replies: 1Last Post: 22nd Jul 2011, 10:42 -
Why is Imgburn DVD Function buried under Mode>Build?
By jimdagys in forum Newbie / General discussionsReplies: 27Last Post: 1st Dec 2008, 18:48 -
CHeaper to build HTPC than buy Hi-Def. DVD player?
By ryangarfield in forum Media Center PC / MediaCentersReplies: 2Last Post: 18th Jan 2008, 14:24 -
Whats the cheapest way to build my dvd collection?
By ryangarfield in forum Off topicReplies: 15Last Post: 12th Jan 2008, 17:20
