hi,
how can i burn an image file and the subtitle file to a cd?
i mean i can burn the image file using the dvd decrypter but then subtitle does not work.
I don't understand your question as stated.
Are you trying to add a subtitle file to an existing video thats contained in a image file?
If so, you would have to extract the video from the image file and add the subtitle file, if it is compatible with the format. What format are the video and the subtitles? -
i have an image file (img) extension and a subtitle file (sub) estension. i can burn img using alcohol but then when i play, i do not see any subtitles
The image file is just the container that holds the file(s), it doesn't tell us anything about what is in there, what format or type of file. It could be Xvid, DVD, VCD or just about any type of file, video or otherwise.
It does appear you have a subtitle file with the .sub extension.
Some types of subtitles are not compatible with some formats of video. Some players do not recognize some types of subtitle files. It makes a big difference what the video format is and what you are using to play the video and the subtitle with.
You might look to these guides and see if they can clarify this somewhat: https://www.videohelp.com/guides#5;20
And since the image file doesn't seem to have anything to do with your problem, I'll move this to our Subtitle Forum where you may get better answers.
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 13:31 -
Video quality worse after burning .srt subtitle into .avi file
By twenty in forum Newbie / General discussionsReplies: 2Last Post: 10th Feb 2010, 07:51 -
Subtitle Workshop 4 crashes when loading subtitle file
By Batou in forum SubtitleReplies: 0Last Post: 26th Mar 2009, 06:57 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 14:37 -
One .PHP Subtitle File, multiple films to subtitle!
By ulrichburke in forum SubtitleReplies: 0Last Post: 20th Mar 2008, 16:32
