Does PYRO A/V Link capture @ 29.97fps? Does it also export at 29.97fps (analog)?
Chuck
You can set it up for pal or ntsc. Some programs can use it for live editing preview as well. Tools like Studio 10 and Liquid edition 6 and Avid Liquid 7..
Still doesn't answer to my original question.
BTW, will use Adobe Premiere Elements 2.0. The only reason I am looking into buying PYRO A/V Link over the ADVC-110 is because the Canopus is $300 while ADS Tech is half of that plus including software. Plan on using firewire instead USB. Capturing will be from Sony Hi8 camcorder and some VHS. Results would be VHS and DVD.
I haven't bought a burner software yet, probably will endup with Nero 6 or 7.
Chuck -
From http://www.adstech.com/products/API-555/specifications/api-555_spec.asp?pid=API-555
Capture Resolution:
NTSC: 720 x 480 @ 30 frames per second
PAL: 720 x 576 @ 25 frame per second
to DV 720x480i/576i
http://www.adstech.com/products/API-555/intro/api555_intro.asp?pid=API-555
"Convert analog video to DV or DV to analog "
They really mean 29.97fps. -
Also The ADVC-110 can be found for $210
http://www.bhphotovideo.com/bnh/controller/home?A=details&kw=CAADVC110&is=REG&Q=&O=pro...ist&sku=349146 -
I thought I did, anyhow, ntsc is 29.7 unless your talking NTSC film. The Pyro will export via svideo, composite and component out as well.Originally Posted by CNT
I would prefer this model, since it's square (unlike the "dome" on the PYRO A/V Link). But, I need to watch my budget (I am building a AM2 system as of this time).Originally Posted by edDV
Chuck -
I would check out www.videoguys.com, they were selling the av pyro in a bundle. I purchased mine from circuit city a while ago for $100... I have no complaints. I also use a pinnacle movie box deluxe as well which I got for $40.
ADS Pyro A/V Link - Firmware u/g to fix VHS dropped frames
By pbanders in forum Capturing and VCRReplies: 16Last Post: 24th Mar 2011, 23:40 -
ADS Pyro A/V Link - black screen
By Brad in forum Capturing and VCRReplies: 10Last Post: 20th Oct 2010, 20:23 -
VHS into Imovie (HD6) with Pyro AV Link Problem
By MacInMass in forum MacReplies: 3Last Post: 9th Apr 2009, 09:25 -
Pyro A/V Link w/Elements not recognised by Vista 32bit
By hhhgamewmx7 in forum Capturing and VCRReplies: 12Last Post: 1st May 2008, 20:51 -
Component video capture with PYRO A /V Link?
By theinv in forum Capturing and VCRReplies: 2Last Post: 19th Sep 2007, 18:47
