hello all!
I've a mini dv tape which has been recorded on a dv camcorder. i've captured it in dv as an avi file. when i open it up in premiere 6.5 (and also studio8) the counter doesn't match that on teh mini dv camcorder display.
i'ved checked project settings in premiere - it should be 25fps (pal) and both capture and edit settings in premiere are correct.
Could it be because im playing mini dv tape from my mini dv camcorder and not someone elses? or could it be that the visible counter on the camcorder is not the actual timecode?
Can anyone help please??
cheers
Can you be more specific? Is the timecode in Premiere similar to that on the camcorder or does it start at 0:00:00:00 (if at the start of the timeline)?
There's a setting in Premiere (if I remember correctly) to tell the software what the real timecode should be. I'm not at my Premiere computer so cannot tell you right now.John Miller -
Just "0:00:00" and not "0:00:00:00" - that seems like a time-of-day (hours:minutesOriginally Posted by devdev
econds) rather than a time code.
Can you confirm that?John Miller
Adobe Premiere export same as original file?
By kray in forum Newbie / General discussionsReplies: 13Last Post: 9th Sep 2012, 01:05 -
how to change saturation and brightness levels to match original video?
By thrakk in forum RestorationReplies: 9Last Post: 10th Sep 2011, 08:58 -
No Timecode on my tape
By towarmforacoat in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2010, 20:49 -
Premiere Pro CS4 outputs 400MB file from 5MB original?
By J-E-T-S in forum EditingReplies: 5Last Post: 20th Jul 2009, 19:46 -
Random freeze or stop while exporting to tape in Premiere Pro CS4
By LghtAndDrk in forum EditingReplies: 1Last Post: 8th Jul 2009, 01:51
