I've just done a set of five separate videos to be burned in one DVD, and they total 4.4Gb. Just a nice size to fit on one DVD.
I am using Sony DVD Architect and it wants to expand this all out to 6Gb !!! (My front end animations are nothing really).
I have rendered these five videos at approx MPG2 720x576.
My question is: can I re-render these videos at a lower screen-size or bitrate (or something else) to reduce their size but, at the same time, maintain a certain quality so they can fit on one DVD?
Thanks.
what type of audio are you using ? ac3 ?
DVDA will not recompress the video if everything is proper (audio and video)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
If you are using the cheap <$1000 version (about $60), I think it will always convert to LPCM which will blow up your file size just like you are seeing.
Ted Rossin
http://www.tedrossin.0sites.net/
I need new Dvd Authoring software ?
By mrjust in forum Newbie / General discussionsReplies: 10Last Post: 28th Mar 2010, 17:13 -
after encoding, file balloons 3x
By uglijimus in forum Video ConversionReplies: 15Last Post: 21st Aug 2009, 14:07 -
Mpeg file size balloons after exporting as FLV or MOV?
By jjachin in forum Newbie / General discussionsReplies: 2Last Post: 16th Jul 2009, 16:56 -
Any DVD authoring tools that are geared for quality + size?
By timmus in forum Video ConversionReplies: 4Last Post: 24th Oct 2007, 23:38 -
Best DVD Authoring Software
By mai_hnf in forum Authoring (DVD)Replies: 3Last Post: 30th Sep 2007, 11:25
