Hi,
I want to convert a whole bunch of AVI files but I need each to be on a seperate chapter within the same title. Is there a program that allows this?
Thanks!
After encoding each AVI to mpg, and bringing them together as one title with the authoring app (TDA suggested), you can put chapter points wherever you want.
/Mats -
Phil
Hi. I recommend the womble MPEG Video Wizard DVD for you. You may do these steps below:
1. Install and open MPEG Video Wizard DVD.
2. Press the button on the Taskbar to open the DVD Maker window.
3. Switch to the 'DVD Tree' page, click the 'Add Video...' from menu (right mouse click), then select the AVI files to open.
4. Apply a menu design template. Switch to the Template page and select a desired menu design.
You can apply the selected menu design to the current DVD project by double clicking on the template icon; or you can apply it via the template control menu as shown.
5. Using the keyboard shortcut 'Ctrl + F2' to set the each chapter name with the their file name.
6. Then you can edit the DVD menu and export the DVD Folders.
Wish to help you.
Chapters missing or out of sequence when converting VIDEO_TS to .AVI or MPE
By Sloani in forum ffmpegX general discussionReplies: 2Last Post: 7th Mar 2010, 11:45 -
Converting AVI to MPEG-2 with no seperate audio file
By Craig876 in forum Video ConversionReplies: 1Last Post: 9th Nov 2009, 18:38 -
Unable to create chapters while converting from AVI to DVD using DVDAuthor.
By sumit_pankaj in forum Authoring (DVD)Replies: 7Last Post: 11th Jun 2009, 02:40 -
2 movies with seperate pagew for chapters of each movie possible?
By perfection in forum Authoring (DVD)Replies: 1Last Post: 28th Aug 2007, 08:10 -
Putting 2 QT Files w/ 2 seperate .srt files onto a DVD
By whoracle in forum ffmpegX general discussionReplies: 5Last Post: 22nd Jul 2007, 03:57
