    Dec 2005
    Hello, I'd like to convert my mp3 to mmf so that I can send it to my friend's Samsung phone via SMS. So what program can do that conversion?
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    A little Googling on your behalf (as I was intrigued by this format) led me to a Yamaha site (the inventor of this format). A couple of clicks, and I found this page - Sound Decorator - a wav to SMAF (.mmf) converter. But I really doubt it can be transfered as SMS, since SMS is max 160 bytes. Possibly MMS.
    /Mats
    Dec 2005
    thanks. I did googled and found a lot, but most of them needs to pay.
    Dec 2005
    grrrrrrr that program u suggested doesn't convert mp3 to mmf. it says it supports only wav and midi.
  5. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    To be fair, Mats did say (changed emphasis mine):
    Converting MP3 to WAVE format is fairly trivial... unless you're trying to avoid double-encoding the file? The sound probably isn't going to be as good as even an MP3 in an MMF file, so it might not make that much of a difference.
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Well, I made the assumption MP3 to WAV would be too trivial to really be worth mentioning, but:
    Load the MP3 in goldwave. Save wav.
    /Mats
    Dec 2005
    nah, I got this PC Sync. It converts direct from mp3 to mmf. I heard that SMS can only send files 200kb or smaller? and the final mmf I got from that conversion is 300kb something, so is there a program that shrinks mmf? I don't mind the worse quality. I googled, but can't seem to find it.
  8. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Basically SMS is limited to 160 byte, and only for plain text messages.
    I don't think you can compress mmf further, but perhaps use a lower sample rate/bit rate in the mp3 you start with? Or cut it down somewhat?
    /Mats
