please dont flame me i tried searching and found nothing. what programs do i use to turn avi files into vob files. i have a pretty big avi file. like 699 mb.
dvd player plays dvd-r if that helps. thanks in advance
A easy program to start with is ConvertXToDVD. It does most everything itself and does a fair job. There is also an older freeware version, DivxToDVD available. With Xvids, you might want to drop the file into Gspot 2.52 first and check for MP3 VBR audio. ConvertXToDVD can handle it most of the time, but it can sometimes cause audio/video sync problems.
The higher quality/steeper learning curve method is to use the individual encoders and authoring programs. If you want to learn about those, look to 'CONVERT' and 'AUTHOR' to the left. <<<<<<
And welcome to our forums.
EDIT: Thanks, guns1inger, I corrected XivdToDVD to DivxToDVD. Thinking Xvid too much.
XvidtoDVD = DivxtoDVD if you are searching, although it will also handle Xvid and a number of other formats. ConvertXtoDVD contains many improvements in many areas. If you just need this for a one-off, try DivxtoDVD. If you are going to do this often, consider buying ConvertXtoDVD, or learning how to use an encoder
Read my blog here.
now how do i put a bunch of avi clips that i converted into 1 ts folder, so i could burn to dvd
doesn't convertxtodvd burn also? or are you using divxtodvd?
or else burn the video_ts to dvd using for example imgburn, nero, guides: https://www.videohelp.com/author#3;25 -
im using divxtodvd
i have no problem burning 1 video ts folder. i wanted to put more then 1 file
i wanted to know how i would compile a bunch of avi files into 1 ts folder to burn on a dvd disc, so i could play it on my dvd player.
im using nero to burn the ts folder no problem. but when i put more then 1 ts folder into the compliation it gets rejected.
why will some avi files play in my dvd player while others will not?
By panman36 in forum Newbie / General discussionsReplies: 6Last Post: 8th Nov 2010, 11:58 -
Converting DVD files to play on DVD player
By xxnonamexx in forum DVD & Blu-ray PlayersReplies: 10Last Post: 10th May 2010, 09:42 -
avi files can only play up to 40 minutes in DVD player, why?
By ericdunn in forum Newbie / General discussionsReplies: 8Last Post: 7th Apr 2010, 09:37 -
Help. What program to use to make avi files play on dvd player?
By xxxThiefxxx in forum Newbie / General discussionsReplies: 13Last Post: 30th Mar 2010, 18:09 -
DVD player to play .avi files
By micallen in forum DVD & Blu-ray PlayersReplies: 11Last Post: 23rd Nov 2007, 15:14
