Got sent a number of Tiff photo files on cd, but one refuses to open in Photoshop (or anywhere else) giving the message "Could not complete your request because the Tiff file uses an unsupported compression method" . Any ideas what the person who scanned and saved could have done wrong or how I can open it ?
I don't know if this guy has figured out the problem yet or not, but for anyone else who is ever visiting this forum and using a PC do this:
Open the file in Microsoft Office Document Imaging. It should open up without a problem. Hit control-A to select the image, then copy image. Then in photoshop open up a new document... it should open up to the size and resolution of the image that you're trying to open.
Then as soon as the new document is open in Photoshop, go to Edit, and then paste. WHALLA. Should work just like that.
Visit my website, www.focusmag.info.
Photoshop question about printed size, DPI, etc
By sdsumike619 in forum ComputerReplies: 4Last Post: 3rd Oct 2009, 11:16 -
Batch convert TIFF to JPG?
By Jeikobu in forum MacReplies: 9Last Post: 21st Sep 2009, 17:55 -
Photoshop question (use layer names as text?)
By sdsumike619 in forum ComputerReplies: 1Last Post: 30th Apr 2009, 18:22 -
Photoshop question (applying a transparent layer to multiple psd's)
By Alex_ander in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2007, 08:34 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
