I recently purchased a Sabrent TV-USB2.0 TV Tuner from Tiger Direct. I knew it would be a piece of junk from the get-go, as it was so cheap (about $39 CAD). I hooked it up to my PC, installed the drivers, installed WinDVR 3, and got everything to work. I recorded a few home-videos from my VHS. A few hours later, I shut my PC off and went to work.
When I arrived home later that evening, my Sabrent capture device wouldn't work at all. I kept getting annoying "cannot detect device" error messages in WinDVR, even though it had previousely worked flawlessly. So a few extremely frustrating hours later, I still couldn't get the drivers to re-install. But I got to the point where when I plugged the device into the USB port, it recognized it as "MEDIA". It wouldn't install.
Sp I got fed up and installed a fresh copy of XP pro. I clicked the bubble that popped up on my icon tray informing me about the "MEDIA" device, and I went through the "Found New Hardware" process for what it called "USB TV Tuner Analog Video". I got to the point where I located the drivers on my CD, and I hit OK to continue with the driver installation. Then my computer reset. I've tried it a couple more times with the USB plugged in, and a few times with it taken out. Still resets... What I don't get is why it worked before, but now it doesn't? This software really sucks big-time... Can someone pleaaaaase help me, because this piece of junk is ticking me off![]()
Anyways thanks,
Garrett8)
Results 1 to 1 of 1
easycap driver installation and use
By cville in forum Newbie / General discussionsReplies: 2Last Post: 19th Sep 2011, 12:11 -
Can I install Win Vista HP with installation CD
By pchan in forum ComputerReplies: 21Last Post: 9th May 2011, 10:37 -
Hauppauge pvr usb2 driver problem after XP install....
By pinetop in forum Capturing and VCRReplies: 14Last Post: 3rd Jul 2010, 01:35 -
HIS 9600pro ATI 128Mb AGP - driver installation ???
By blinky88 in forum ComputerReplies: 6Last Post: 22nd Sep 2009, 05:52 -
Help PDF printer driver install
By jollyjohn in forum ComputerReplies: 3Last Post: 5th Mar 2009, 09:18
8)
