Does anyone know how to convert a NTSC vhs to a PAL vhs.
One possible that I've thought about is that I could capture the NTSC vhs to the computer in PAL mode and recorded it back to a vcr(NTSC vcr). Does that work?
-Thanks
yes that will work, but you will have the same old problem that happens when ever you try to convert any type of movie from NTSC to PAL or vice versa, just make sure you capture into PAL.. Im not sure if you can record it back onto an NTSC vcr..? It may be possible.
also if you just hook up 2 VCRs, one ntsc and one thats capable of recording into PAL it would be easier. either way heh.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
