I have just purchased a WinTV PVR 150 and after installing the computer freezes before windows can load. After fidling around and removing other cards from my PC I have found that the PC will load with WinTV PVR 150 in place if I remove my video card (Geforce 7600 GS). Now the PVR 150 works fine but now I don't have a video card to use and vice versa. Has anyone else had this problem or now how to fix this problem so I can use both cards together.
I tried it in all slots but had the same problem. The only thing that has solved it was to remove my video card.
So it work with onboard Geforce 6100 GPU but not Geforce 7600 GS GPU have check with Gigabyte for newer bios also it possable your nForce chipset, nic or audio drivers need updating.
If anyone is having this problem, I know the solution. Gigabyte has written a custom BIOS to solve this but it's only for the GA-M55PLUS-S3G rev.2 board. Contact me if you need it. If you have a rev.1 board, contact Gigabyte. They may do the same for you but they might need to borrow your WinTV card.
Chris
Capture Lossless with WinTV-PVR-150
By rudolf016 in forum Capturing and VCRReplies: 50Last Post: 28th Feb 2012, 12:39 -
Bitrate problem - PVR-150
By m0dts in forum LinuxReplies: 4Last Post: 14th Dec 2009, 14:47 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 11:39 -
Hauppauge WinTV PVR-150 ($60) vs. ATI TV Tuner 650 ($100)
By RoganSarine in forum Capturing and VCRReplies: 2Last Post: 13th Dec 2007, 03:48 -
Color Bleed on Hauppage WinTV-PVR 150
By TheBladeRoden in forum Capturing and VCRReplies: 3Last Post: 14th Jun 2007, 10:05
