I read somewhere that when you are doing a conversion from DVD to Xvid, to have the encoded file able to be fast-forwarded or rewinded to a particular point, where the audio and video will be in sync, the correct keyframe rate value has to be entered. The DVD i tried using AutoGordian Knot is a concert, and everything worked great EXCEPT when i fast forward or rewind to a particular point, the sync between the audio and video is DESTROYED! Please suggest a keyframe rate value so i can get things sync'd even when fast-forwarding or rewinding.
thanks!
Video is refusing to play - Keyframe issue?
By jairovital in forum EditingReplies: 14Last Post: 26th Feb 2012, 12:45 -
Virtualdub keyframe picture doesn't match the actual video
By yuvid in forum EditingReplies: 1Last Post: 1st Feb 2012, 02:57 -
FFMpeg - warning: first frame is no keyframe - Encode to nearest keyframe?
By mh2011 in forum EditingReplies: 0Last Post: 3rd Nov 2011, 16:58 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Video splitting without having to split from the keyframe?
By andy_blah in forum Video Streaming DownloadingReplies: 13Last Post: 8th Aug 2008, 12:05
