Well what happens is when I open up mozilla it'll open up 3 tabs, 1 my homepage and 2 tabs being the last 2 sites I went to. It'll do the same when I click on my home icon. Any idea why this is ? I imported my settings from my old drive to my new ( didnt have problem on old drive ) All I did was tweak the speed in the config and did something for popups. Nothing changed for tabs as far as I know anyways.
In options, you can set the default homepage to be a bookmark. If that bookmark is a folder with more than one URL, it will open all of them.
mmmmm the pages that comes up in the 2 tabs are not bookmarked, neither is my homepage.
Did you try re-entering your homepage in the Options->General section? Specifically, you could have multiple URLs set to load if there is a pipline character (|) in between URLs.
Also, type in about:config in the address bar and look through some of your settings, especially:
browser. startup. homepage_override. 1 should be FALSE
browser. startup. page should be set to 1 (assuming you want to start at your homepage) -
Do you have session saver extension? Might be an issue with that if so.
Mozilla Seamonkey Problem Installing Shockwave Flash Player
By bevills1 in forum ComputerReplies: 2Last Post: 2nd Jul 2009, 11:47 -
mozilla is trying to set a one day download record today 6/17 w/firefox 3
By aedipuss in forum ComputerReplies: 27Last Post: 3rd Jul 2008, 10:03 -
Mozilla is becoming *VERY* idiot-friendly :-(
By Midzuki in forum Off topicReplies: 10Last Post: 25th May 2008, 16:12 -
Mozilla Firefox
By maccool111 in forum ComputerReplies: 3Last Post: 7th Apr 2008, 21:31 -
Internet Explorer and Mozilla Firefox
By kimco52 in forum ComputerReplies: 19Last Post: 10th Jun 2007, 04:06
