I was wondering if there is a simple way to do this with TMPGEnc. I noticed thats my ony problem I have. If I use VIRTUAL dub the audio is sometimes out of sync. I can convert all DIVX avi to SVCD fine if the avi is in 44100 rate audio. Is it even possible. When I did covert with the audio still in 48000 rate NERO tried to convert once again.
So to sum it up i need to convert 48000 rate audio to 44100 the easiest way without VIRTUAL DUB, thanks.
Results 1 to 1 of 1
Audio Sampling Rate Info Wrong - DV-AVI Capture
By newtotheworld in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2011, 22:18 -
DVdate: DV-AVI Type 1> 2 conversion unexpectedly altering audio sample rate
By simonm in forum Video ConversionReplies: 1Last Post: 4th Nov 2010, 08:54 -
DVD to DivX - Chapter Decoding Problem
By Nuin in forum DVD RippingReplies: 0Last Post: 25th Mar 2009, 17:56 -
Avi lowering Frame rate and audio
By vipertongn in forum EditingReplies: 8Last Post: 14th May 2008, 03:31 -
How to change the audio from 44100 to 48000 using Aften?
By php111 in forum AudioReplies: 13Last Post: 2nd Oct 2007, 19:58
