I'm trying to capture from vhs to pc/dvd the recording is about 90 minutes I'm using a cable with rca to usb and Turtle Beach Video Advantage software. Problem is 33 minutes recorded as an avi took 40 gig. Right now I'm converting the 40g partial file to mpeg-2 with Blaze Media Pro. Does 40 gig sound right? Or did I capture it wrong?
downloaded it but not sure how to install it, what I have installed though is YUY2, UYVY, and 1420 any of these better?
To install HuffYUV, unpack the archive, right click on the INF file, and select install from the popup menu.
YUY2 and UYVY are just different orders of the same 4:2:2 subsampling. I420 is a 4:1:1 subsampling and will be a little smaller, but it will also have less color resolution.
After installing HuffYUV your software should have some way of selecting a compression codec. Capture as YUY2 and use HuffYUV. That should reduce your file size by about half with no loss of quality. -
Thanks, I must have downloaded the wrong one mine doesn't have an install when I right click on it. I'll look for another one and see if I can get this program working. In the mean time Power Director (which came with the bundle) is capturing it using about 10% of the space VA was using. I've been using Video Advantage for all my little jobs 5-10 minutes and like it this is the first time I've tried a bigger job with it. It's the first time of tried this Cyberlink software we'll see hopefully it doesn't look like crap.
If you downloaded the version linked to from videohelp.com:
http://neuron2.net/www.math.berkeley.edu/benrg/huffyuv-2.1.1.zip
the zip file contains 3 file:
huffyuv.dll
huffyuv.inf
readme.txt
After extracting the files right click on huffyuv.inf and select "Install".
If you have Windows set up to "Hide extensions for known file types" you won't see "huffyuv.inf", just "huffyuv". I'd also recommend you disable that "feature" of Windows. Seeing file extensions is critical to the use of Windows.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 10:32 -
Capturing video from a European VHS tape through RCA out
By c627627 in forum Capturing and VCRReplies: 71Last Post: 23rd Mar 2010, 15:19 -
"No signal"-capturing from VHS-tape
By Mållgan in forum Capturing and VCRReplies: 7Last Post: 19th Sep 2008, 04:21 -
Question about capturing VHS tape to .avi file
By rfdillon in forum Capturing and VCRReplies: 6Last Post: 27th Jul 2008, 01:44
